Square Shank Holders Increase Tool-Location Accuracy
Carmex’s square shank holders provide through-coolant capability and are designed for use with the company’s 3-, 4-, 5- and 6-mm diameter Tiny Tools.
Carmex’s square shank holders provide through-coolant capability and are designed for use with the company’s 3-, 4-, 5- and 6-mm diameter Tiny Tools. Featuring a compact, rigid design, the holders are said to provide accurate tool location for operations such as boring, back turning, profiling, threading, chamfering, grooving and more. A special adapter simplifies the coolant connection. According to the company, the toolholders increase stability and help minimize vibration for increased accuracy, improved finish and extended tool life.
Jergens Pull Studs Enable Quick Changeovers
SP140 and K02 pull studs offer quick-change solutions for vise or gripper jaws, electronic component manufacturing, packaging machines, medical technology and automation.
Quick-Change Collet Chuck Doubles as Mandrel
The hybrid Comot-AZ quick-change collet chuck from SMW Autoblok can be used for OD machining and can be transformed into an expanding mandrel for ID clamping using the EMX series.
