Stainless Steel Parts Washer Features Modular, U-Bend Design
The company’s PWRB9-36EU aqueous parts washer is designed for precision cleaning of large metal parts and large batches of smaller parts.
Almco’s PWRB9-36EU aqueous parts washer is designed for precision cleaning of large metal parts and large batches of smaller parts. Constructed entirely of stainless steel, the unit features a compact, U-bend design to enable a single operator to load and unload parts from one location. Other features include rinse and blow-off capabilities and modular construction, which facilitates adding various stages as-needed to suit user requirements.
A 9"-wide, flat-wire belt carries individual parts or batches of parts through the system. Parts are cleaned with a heated solution that is sprayed from adjustable nozzles at the top, bottom and sides of the 36"-long cleaning chamber. Built-in cyclonic filtration equipment recycles liquids for reuse and for environmentally safe disposal of solid particles and floating matter.
CTG's Parts Washing Machine Supports Lean Manufacturing
PMTS 2023: The Ransohoff LeanVeyor parts washing system reduces floor space requirements and provides optimized cleaning and drying performance.
NMP's Parts Cleaning Systems Pass Upcoming Regulations
PMTS 2023: ITF Parts Washing Equipment machines are designed to help prepare and sustain manufacturers for the upcoming environmental regulations in North America.
Madison Chemical Degreaser Easily Removes Machining Oil
ProClean Degreaser quickly and completely removes oil and grease with its superior wetting and penetrating properties.
