Steady Rest Supports Shafts for Grinding
SMW Autoblok’s SRG steady rest is designed to support shaft-type workpieces on grinding machines.
SMW Autoblok’s SRG steady rest is designed to support shaft-type workpieces on grinding machines. Retractable arms enable rapid set-up and make the steady rest suitable for follow-down grinding, while horizontal and vertical fine adjustments of the grinding center enable high-precision grinding. Additional features include a port for compressed air, stroke control and central lubrication. Suitable for crankshaft and camshaft applications, the steady rest is available in three sizes with clamping diameters ranging from 20 to 85 mm.
  • Modern Bar Feeds Bring New Life to Automatic Swiss Lathes
    Cam-actuated Swiss lathes are still the fastest way to process many parts. By adding modern bar feeders, this shop has dramatically improved their utilization with the ability to work unattended, even in a lights-out environment.
  • An Additive Manufacturing Machine Shop
    Finish machining additively manufactured implants requires different pacing and workflow than cutting parts from stock — different enough for an experienced manufacturer to warrant a dedicated machine shop.
  • Moving To Magnets Doubles Productivity
High Accuracy Linear Encoders
