Sump Vacuum Separates Fluids for Reuse
Cecor’s Sump Shark high-suction sludge vacuum is designed to clean dirty sumps and separate industrial fluids from solids for recycling.
New Product From: 7/4/2014 Modern Machine Shop, , from Modern Machine Shop
Cecor’s Sump Shark high-suction sludge vacuum is designed to clean dirty sumps and separate industrial fluids from solids for recycling. In addition, the company's discharge filter can couple to the sump cleaner’s existing discharge port for second-stage filtering, using 10- and 25-micron filter bags. The combination of vacuum and filter results in less fluid use and, therefore, less disposal costs for a greener process, the company says.
See what you missed at IMTS!
Check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology, then watch Shop Talk to get the Modern Machine Shop editors’ take on IMTS, the trends they’re seeing, and what’s coming next in your industry.
Learn More about IMTS
Learn More
CECOR
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
