Surface Grinder Built For Stability, Precision
  SPAN.ekMisspelled { BACKGROUND-POSITION: left bottom; BACKGROUND-IMAGE: url(http://gpi.gardnerweb.com/ewebeditpro3/wavyred.gif); BACKGROUND-REPEAT: repeat-x; isStyleInternal: Tru The ACC-16·32CA1 MDI control surface grinding machine features a rigid, T-frame traveling-column design for stability and precisi
New Product From: 8/7/2008 Modern Machine Shop
 The ACC-16·32CA1 MDI control surface grinding machine features a rigid, T-frame traveling-column design for stability and precision. The machine’s wide-frame design and construction is said to virtually eliminate accuracy-robbing table overhang. Ribbed Meehanite cast iron construction is used throughout.
Chuck size is 32" × 16", and table load capacity (including chuck) is 2,204 lbs. Maximum clearance under the grinding wheel to table is 19.57". A 10-hp grinding wheel spindle motor can deliver speeds ranging from 500 to 2,500 rpm, and standard wheel size is 16" × 2" × 5". The grinder is equipped with a hydraulic overhead wheel dresser, automatic lubrication, an oil-fan cooler, machine splashguards and more.
Other features include a chuck or work datum MDI control system; a shift-plunge/traverse grinding cycle, in which the machine automatically shift-plunges for fast stock removal before traverse grinding for fine finish; an 8.4" color LCD display; rapid wheel head advance and retraction; ballscrew-driven cross feed and vertical feed, along with a manual pulse generator for cross feed positioning; and a dress interrupt function.
Okamoto Corporation.
MMS Zones
Zones
Supplier Categories
LANDIS ECOFLEX Grinder - flexibility to reduce your carbon footprint without sacrificing quality or productivity
