System Enables Through-Coolant on Swiss-Type Machines
After retrofitting its ReCool through-coolant system for live tooling on CNC lathes, Rego-Fix has expanded the coolant system to provide internal cooling capabilities to static toolholders on Swiss-type automatic machines.
After retrofitting its ReCool through-coolant system for live tooling on CNC lathes, Rego-Fix has expanded the coolant system to provide internal cooling capabilities to static toolholders on Swiss-type automatic machines. According to the company, the static ReCool system quickly converts a standard Swiss-type tooling collet locking nut into a coolant-style nut using the IntRLox anti-slip nut design. Changing tooling involves simply loosening and removing the locking nut and supply piping. Rated at coolant pressures as high as 1,450 psi with a standard hose and 2,100 psi with a braided hose, the static ReCool design can replace standard ER mini-nut types 16 and 20. It works in conjunction with the company’s coolant disc systems DS/ER and KS/ER.
The company says that using and changing through-tool coolant in the tight confines of a Swiss-type machine has traditionally required working with coolant plumbing passing through the back of the machine tool block. Rego-Fix’s ReCool system eliminates the need to work behind the tool block, reducing setup and tool change time. By sending coolant flow directly to the cutting edge, through-coolant operation benefits tool life and speeds chip removal.
T.J. Davies Retention Knobs Maximize Cutting Tool Life
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
