Tap Designed to Thread a Range of Materials
The MultiTAP is a high-performance tap designed to cut a variety of materials, such as carbon steel, steel alloys, stainless steel, aluminum, cast iron, copper, brass and bronze.
New Product From: 4/5/2011 Modern Machine Shop
The MultiTAP is a high-performance tap designed to cut a variety of materials, such as carbon steel, steel alloys, stainless steel, aluminum, cast iron, copper, brass and bronze. The tap is also engineered to produce threads within both 2B and 3B classes of fit, eliminating the guesswork of calculating H-limits, the company says.
The tap is suited for job shops or manufacturers that work with short- and medium-run threading applications across a spectrum of materials. It is said to improve thread quality and boost output while reducing production costs because it can handle most common materials and applications. According to the company, the tool eliminates the need to stock numerous types of taps in the tool crib.
The tap is constructed of a proprietary grade of high speed steel (HSS-E), nitrided with a Ne2 surface treatment. It is available in both spiral-point and spiral-flute configurations for through- or blind-hole applications. Tap sizes cover a full range for UNC or UNF threads, including inch sizes ranging from #4-40 to ¾"-16 to metric sizes ranging from M4 × 0.7 to M16 × 2.0.
Emuge Corp.
MMS Zones
Emuge Corp.
Zones
Supplier Categories
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Learn more on tooling suppliers in the Tooling Resource Center.
Premium tooling and technology for high-quality, precision machining.
