Thread Milling Software Eases NC Code Generation
OSG says its ThreadPro thread milling NC code generator software is said to eliminate the hassle of having to enter data as text, copy and replace.
OSG says its ThreadPro thread milling NC code generator software is said to eliminate the hassle of having to enter data as text, copy and replace. The adjustable configuration of multiple paths has been simplified to enable the easy creation of zero-cut programs. Single feed (one pitch per cut), which is suited for machining materials with high hardness, is available in addition to multiple feed (machining at each cutting edge length). The capability of reviewing machining trajectory enables users to confirm trouble-free tool movement to minimize tool damage.
The software is available in 12 languages and supports eight NC programming languages. It incorporates a RPRG (radius programming) value to reduce setup and machining time, and promote tool life.
When to Use Custom Macros With a CAM System
Custom macros can offer benefits even when using a CAM system to prepare programs – but must be implemented with the right considerations.
Building A Powerful Bridge from the CAM Programmer to the Shop Floor Operator
SolidCAM for Operators provides a powerful bridge from CAM programming to the shop floor to best streamline the machine shop process with its CAM part simulation. It provides a clear picture to the operator for setup and prove-out, enables minor G-Code changes and avoids crashes, broken tools and scrapped parts.
