Tool Grinder Features Wheel/Nozzle Changer
Rollomatic has expanded its series of multi-axis tool grinding and peel grinding machines with the GrindSmart 528XW five-axis CNC tool grinding machine with wheel/nozzle changer.
Rollomatic has expanded its series of multi-axis tool grinding and peel grinding machines with the GrindSmart 528XW five-axis CNC tool grinding machine with wheel/nozzle changer. The machine features a “synchronous” grinding spindle with technology that enables higher torque and improved surface finishes. Together with software developments, the multi-axis tool grinding machine offers versatility and capability for rotary and stationary cutting tools such as end mills, drills, form tools, indexable inserts, taps, reamers and routers as well as medical instruments.
The company also offers its ShapeSmart NP5 five-axis pinch/peel grinding machine. Pinch grinding offers highest concentricity even on long and thin parts.
