Tool Grinder Supports Small Batch Regrinding
Strausak, a division of Rollomatic, will exhibit its U-Grind five-axis CNC tool grinder at IMTS, featuring thermal stability to ease consistent, accurate, small batch production and regrinding.
New Product From: 7/24/2014 Modern Machine Shop, , from Modern Machine Shop
Strausak, a division of Rollomatic, will exhibit its U-Grind five-axis CNC tool grinder at IMTS, featuring thermal stability to ease consistent, accurate, small batch production and regrinding. The machine comes with an automatic wheel changer and a direct-drive 12-kW (17-hp) grinding spindle with an optional automatic loader. An automatic quick-change system eases collet and tool change, along with an ISO 50-taper toolholder. A touch probe is available as an option for grinding wheel qualification.
The machine uses the NUM Fleximum CNC and the NUMROTOplus tool grinding software, providing 3D tool simulation, machine animation and collision checking, as well as digitization of existing cutting edges for regrinding or grinding pre-fluted tools. Additional software is available for complex step/form tools, hobs, burs, shape cutters, T-slot cutters, high-performance end mills and drills, routers and other types of cutting tools.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Rollomatic Inc.
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
