Toolholders Designed for Grooving, Turning
Schwanog’s WSI toolholding system is designed for ID grooving of complex contours, turning, or a combination of both applications.
Schwanog’s WSI toolholding system is designed for ID grooving of complex contours, turning, or a combination of both applications, enabling users to reduce unit costs. The toolholders carry coolant through and can be applied for IDs greater than 2 mm. The lengths of ID plunge carbide inserts can be variable adjusted in the Z axis through a set screw, providing rigidity and functionality during setup and tool change-over. The repeatability of the system is less than 0.02 mm.
Simulation and Tooling Secure High-Value Work
Simulation software and careful attention to tooling parameters have enabled Major Tool to take on ambitious projects with its complex machinery.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
