Toolholding System Offers High Performance at Fast Speeds
Parlec’s high-performance Eros toolholding system is said to offer high velocity, improved cutting performance and longer tool life.
Parlec’s high-performance Eros toolholding system is said to offer high velocity, improved cutting performance and longer tool life. The design of the collet seat and collet nut combined with tight tolerances promote high gripping force. The chuck body and nut utilize two pilot diameters, one above and one below the threads, to give the nut the best radial position to the seat and avoid clamping distortion. The holders are balanced to G2.5, and the aerodynamic design of the nut enables high performance at fast speeds without unbalance or vibrations, the company says. The toolholding system is said to provide concentricity of less than 0.00012" at 3×D.
Jergens Pull Studs Enable Quick Changeovers
SP140 and K02 pull studs offer quick-change solutions for vise or gripper jaws, electronic component manufacturing, packaging machines, medical technology and automation.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
