Tungaloy Adds Changeable-Head Tool to Drilling Grade Series
Tungaloy is expanding its AH9130 drill head grade series to include the DMP drill head line from the DrillMeister changeable-head drill series.
Tungaloy is expanding its AH9130 drill head grade series to include the DMP drill head line from the DrillMeister changeable-head drill series. A self-locking interface connects the drill head and tool body to simplify tool changes. Operators can replace the tool without removing the drill body from the adapter or re-measuring tool offset values,
This AH9130-grade expansion encompasses the DMP line of general-purpose drilling, succeeding the DMC drill head for precision drilling. Developed specifically for drilling applications, AH9130 is a nano-multilayer PVD coating consisting of three layers. This coating configuration is designed to provide longer, more predictable tool life by adding wear, fracture and oxidation resistance as well as resistance to buildup and delamination.
Walter Offers New Solid-Carbide Taps for Blind-Hole Machining
Walter’s TC388 Supreme and TC389 Supreme feature patent-pending cutting geometries that fully shear off the root of the chip when reversing, thus minimizing torque peaks.
Walter Launches New Solid Carbide Drill
The DC118 Supreme solid carbide drill provides high rigidity against deflection, superior centering accuracy and four margins with corner chamfers.
