Tungaloy's TungBoreMini Combines Drilling and ID, OD Turning
The TungBoreMini, a multifunctional drilling and turning tool from Tungaloy, is designed to combine the capabilities of drilling and OD and ID turning tools.
The TungBoreMini, a multifunctional drilling and turning tool from Tungaloy, is designed to combine the capabilities of drilling and OD and ID turning tools. This combination is said to provide time savings compared to changing tools and increased machine utilization rates, especially for aluminum applications.
The insert and pocket feature a dovetail interlocking design providing better insert clamping and stability during various applications, compared with conventional screw-down insert retention, according to the company.
Eight holders are available in diameters of 10, 12, 14 and 16 mm (0.394", 0.472", 0.551" and 0.630"), each in right- and left-hand models. Inserts are available in four different sizes to fit the corresponding holders.
Walter Offers New Solid-Carbide Taps for Blind-Hole Machining
Walter’s TC388 Supreme and TC389 Supreme feature patent-pending cutting geometries that fully shear off the root of the chip when reversing, thus minimizing torque peaks.
Tungaloy Expands Drill System With Drill Sleeves
Adding drill sleeves to the standard lineup enhances drilling productivity of Swiss-type sliding-head automatic lathes.
