Turn-Mill Capable of Additive Manufacturing
WFL Millturn Technologies will display the 4,500-mm M80 Millturn, a hybrid machine which combines turn-mill capabilities with additive manufacturing.
WFL Millturn Technologies will display the 4,500-mm M80 Millturn, a hybrid machine which combines turn-mill capabilities with additive manufacturing. The M80 has been equipped with a 6-kW high-performance laser for melting powdered metals and low-distortion hardening. The machine also provides high build-up rates for cladding, making it possible to create nearly any geometric form through the use of the machine’s NC-axis capabilities. This enables the efficient, complex manufacturing of cooling channels or curved, connecting flanges.
The company will also display the smaller M50 Millturn for gear cutting.
  • Controlling Extreme Cutting Conditions in Large-Part Machining
    Newly patented technologies for controlling chatter and vibration during milling, turning and boring operations promise to drastically reduce production time and increase machining performance.
  • Palmgren Launches Combination Bench Lathe, Mill
  • When Too Many Customers Spoil the Part
    Duo CNC used to take on as many customers as the shop could handle. But when growth stalled, a top-down audit by the company’s general manager revealed that its customer base was inhibiting growth — and causing the shop to be less efficient and productive.
Okuma
Gravotech
Gardner Business Intelligence
