With three 14-position tool turrets and identical main and counterspindles, the new space-saving Index C100s are designed for fast, cost-competitive production of medium complexity parts turned parts from bar stock from 30 to 42 mm diameter. The C100 will be at IMTS Booth S-8136.
Ideal for small to medium lot sizes, the three-turret machines deliver high performance within a small floor space, and are targeted to handle fixed headstock work often run on Swiss-type machines.
The Index C100 offers users a highly productive means of machining stock in the 30 to 42 mm range with more tools (42 quick-change tools, fixed and driven), higher horsepower, and greater torque but with the rpm typical of Swiss-style machines.
The C100 with 30-mm bar capacity comes with 9,000-rpm spindles and 42-mm bar capacity is available with 7,000-rpm spindles. Both versions can run parts ranging to 200 mm in length. The C100 drives are powerful: 20/29 kW and 25/29 kW (100/40 percent) for the 30- and 42-mm versions, respectively. Motorized main and counterspindles are identical and liquid-cooled.
The machining flexibility of the C100 is a keynote of Index technology. Up to three tools can be at work simultaneously with both Y axes and backworking at the same time. And the counterspindle with linear-motor driven Z axis can be synchronized with travel of turret 3. Counterspindle pick-up from the spindle is accomplished in just 1.5 seconds.
Because the C100 is configured to complete a wide range of parts from simple to complex, small to large batch sizes, users can expect extremely high machine utilization rates, which allow the C100 to be very cost-effective. Parts can be unloaded from the main or counterspindle.
Simultaneous machining with two Y axes at the main spindle or a Y axis at the main spindle and also one at the counterspindle—each with 70 mm of travel—gives users the option to divide machining operations for optimum machining efficiency and flexibility This freedom also is a key to reduced cycle times. For example, users can machine simultaneously with up to three tools driven tools for complete machining in a single set-up, including heavy milling, and backworking with up to five tools.
The turret slides move in the X and Z directions on innovative single-plane guide ways. This permits rapids up to 60 m/min. and accelerations up to 1 G with maximum rigidity. The plate-type guideway of the turret slides also means turrets glide directly on the machine bed, assuring high stiffness and dampening, resulting in longer tool life—up to 30 percent longer tool life and better surface finish.
The open work area and vertical-bed machine design permits clear chip fall.
Each position on the 14-station turret is equipped for preset driven tools. Large tooling capacity means short setup times and very fast cycle times even for small batches. Tools are more easily accessible than on a Swiss machine and can be changed quickly. They lock with only one screw.
The CNC is easy to work with; plain text is used in display and operation and the screen shows all spindles and axes at one view. Superior programming with more than 70 user routines offers practical support down to the finest detail. Index programming contributes to optimum machine utilization and maximum productivity.
Assuring operator safety was a design consideration for the C100. Absolute measuring systems know axis and tool positions in every situation.
Visit the company's IMTS Showroom here.
Medical Manufacturing Must-sees
The realm of medical manufacturing includes precision cleaning, exacting tolerances, additive manufacturing, ins and outs of FDA clearance and more. Anyone in the industry can learn more and keep up to date with latest in medical manufacturing at IMTS.
Read MoreIMTS 2022 Review: Attention to Automation Extends Beyond the Robot and the Machine
Read MoreNASA Brings Technology to New Heights
Meet NASA mission system engineer Mike Menzel and learn more about the James Webb Space Telescope at Mitsui Seiki USA’s booth (338700) in the South Hall from 11:00 a.m. to 11:45 a.m. on Thursday, September 15.
Read MoreShowcasing the Benefits of Some Oft-Overlooked Grinders
Brent Donaldson of Modern Machine Shop sits down with Supertec's Don Staggenborg to discuss what the IMTS veterans brought to this year's show.
