Tornos' MultiSwiss features the production capability of a six-spindle CNC and the sliding headstock feed of a Swiss-type, single-spindle turning center. The turning center is designed to accommodate parts less than 14 mm in diameter and features 14 linear axes, seven C axes and room for as many as 18 tools (three per position).
Standard tooling can be used on the machine. Quick-change flexibility and open access to the machining area increases productivity and ease of use.
More technology – a lot more!
Learn More about IMTS 2012
