Turning Centers Available with Range of Automation Options
IMTS 2018: Murata Machinery’s line of Muratec turning machines will be on display, including live demonstrations.
The MW35 all-electric, compact turning center with a servo high-speed loader (single or twin gantry loaders are available) is said to produce small parts in as little as three seconds. The machine has two spindles capable of simultaneous multi-tool cutting. The MW40 is designed for minimal thermal displacement during machining operations of smaller parts with tight tolerances. The machine is available with live tooling and Y-axis milling capability.
The MW120 twin-spindle CNC turning center reduces cycle time with a high-speed gantry loader and turret axes. The machine is capable of production times as low as 16 seconds per part. The MD120 automated CNC turning center accommodates live-tooling capabilities, including drilling and milling in every turret position. The integrated three-axis gantry robot loader enables versatile automation possibilities with increased productivity and process flexibility.
The MT100 opposed spindle machine has a built-in Y-axis for greater precision on complex parts, the company says. The machine is designed for each turret to serve either of the twin spindles. Upper and lower turret configuration enable the flexibility to manage two tools in a single cut while reducing cycle time. A variety of automation options include an optional third turret and a three-axis gantry robot. The MT200 opposed-spindle-type machine accommodates larger parts with a turn diameter ranging to 8.3" and an 8" chuck.
Sumitomo Offers Quick-Change System, Chipbreaker for Swiss-Type Machining
The PSZ Turn System offers products for front-turning, grooving, thread-cutting and back-turning applications. Additionally, the MEFF Chipbreaker enables excellent chip control, low cutting force and good surface finish at a range of depth of cuts.
Cermet Turning Insert Maximizes Dimensional Accuracy
Walter’s cermet turning insert is designed to ensure dimensional accuracy, superior surface finish and reduced vibration.
