Turning Centers Feature Wider X-Axis Guideway for Accuracy
The L500LMA series of turning centers from Hyundai-Wia is suitable for heavy-duty cutting.
New Product From: 8/19/2014 Modern Machine Shop, , from Modern Machine Shop
The L500LMA series of turning centers from Hyundai-Wia is suitable for heavy-duty cutting. Featuring a chuck size of 21", the series fills the gap between the company's L400 (15" chuck) and L600 (24" chuck) series.
With a through-hole of 181 mm (7.1"), the main spindle is built with accuracy and rigidity in mind. Double-row precision roller bearings in the rear and angular bearings at the front of the spindle promote cutting accuracy at spindle speeds of 1,500 rpm at 40 hp, producing 2,990 foot-pounds of torque. A spindle oil chiller is used to maintain ambient temperature of the structure. The built-in MT no. 5 tailstock quill taper has a quill diameter of 132 mm (5.2"). The machines are equipped with powerful box guideways, including a wide X-axis guideway for precise and rigid heavy cutting. The X- and Z-axis travels measure 400 × 2,210 mm with XY rapid traverse rates of 20 m/min. and 18 m/min., respectively. The series uses a FANUC 32i-B controller.
The turning centers can also be equipped with include a larger spindle unit, an extra-long bed and Y-axis capability. Options include special-purpose chip conveyors, a high-pressure coolant system and part probing.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Hyundai WIA Machine America
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
