Ultrasonic Cleaner for Cleaning without Solvents
Ultrasonic’s Ultra 3200FA is a full-featured ultrasonic cleaner with 55-gallon main tank capacity and horizontal transducers designed to improve cleaning capability without solvents.
Ultrasonic’s Ultra 3200FA is a full-featured ultrasonic cleaner with 55-gallon main tank capacity and horizontal transducers designed to improve cleaning capability without solvents. The model features an agitation table, dual filtration, 10-gallon weir tank, sparge bar and an insulated tank and lid.
The V bottom is designed to ease cleaning between batches. Side-mounted transducers reduce dead spots so the cleaning action is consistent from top to bottom. The product features 5,040 W of ultrasonic power, dual 2,000-W heaters and a basket capacity of 27" × 18.5" × 5". The Ultra 3200FA can clean parts made of rubber and plastic as well as bearings, bolts, transmission components, engine parts prior to assembly and plastic-injection molds.
Digital touch controls enable operation with automatic ultrasonic, agitation and filtration cycles. A seven-day heat and auxiliary timer enables programming to suit production requirements.
The agitation table capacity of 300 lbs. can hold large parts or multiple batches of smaller components. An optional dual-basket configuration is available, enabling smaller baskets to be processed simultaneously. The ultrasonic cleaner features a working depth of 14".
Alliance Manufacturing's Cleaning Systems Use Safe Solvents
PMTS: The company’s vacuum degreasing machines use solvents to remove contaminants from manufactured parts without the use of water or scrubbing.
Kyzen Solvents Provide Ease of Cleaning for Medical Parts
The Metalnox line of solvent products are designed to improve reliability and increase the ease of cleaning in vacuum and vapor degreasing processes.
CTG's Parts Washing Machine Supports Lean Manufacturing
PMTS 2023: The Ransohoff LeanVeyor parts washing system reduces floor space requirements and provides optimized cleaning and drying performance.
