Unisig's UNE Gundrilling Machines Provide Flexibility for Job Shops
Unisig’s next generation of UNE gundrilling machines is said to provide operational flexibility, improved performance and easier operation.
Designed for manufacturers in high-volume/low-mix or low-volume/high-mix production environments, Unisig’s next generation of UNE gundrilling machines is available in five models built from two frame sizes. UNE machines can drill hole diameters ranging from 1.4 to 40 mm with depths up to 3,000 mm. Compact construction is an advantage for positioning and relocating the machine on crowded shop floors. The machines also can be equipped with robotic automation.
The single main spindle servo motor delivers the necessary horsepower for the two-spindle machines. When power is applied in single-spindle mode, however, shops can produce larger-diameter holes to increase their capabilities and add new business without adding a new machine, Unisig says.
Rather than a pressure-based coolant system, the UNE series features a programmable flow-based coolant delivery system to provide the right amount of fluid to the tool’s cutting edge.
An automated door option can benefit companies with or without automation by reducing fatigue and improving throughput.
How to Grow the Business with Real-Time Job Status Data
Finally, A Comprehensive Software Solution Designed for Small Job Shops
Solve Worker Shortages With ACE Workforce Development
The America’s Cutting Edge (ACE) program is addressing the current shortage in trained and available workers by offering no-cost online and in-person training opportunities in CNC machining and metrology.
