Updated CAD/CAM Software Streamlines Job Setup
CNC Software Inc. has released Mastercam 2019, developed to streamline the manufacturing process from job setup to job completion.
CNC Software Inc. has released Mastercam 2019, developed to streamline the manufacturing process from job setup to job completion. This version is said to increase machining productivity and reduce overall production costs with new 2D through multi-axis milling automation features, CAD and model preparation improvements, expanded 3D tooling, Accelerated Finishing, and turning and Mill-Turn enhancements.
Mastercam 2019 increases productivity and programming efficiency while reducing overall production costs with a series of automated 2D through five-axis tool path improvements. Re-engineered chamfering and holemaking strategies and new Multiaxis deburring provide time-saving automation and simplicity. New milling strategies, like the high-speed Equal Scallop tool path, offer both machining performance and surface finish improvements. The new release includes additional support for the Sandvik Coromant PrimeTurning method, enhanced grooving, bar feed and other features for turning and mill-turn applications, plus new lathe and Swiss-style machine support.
The software increases efficiency and reduces job setup time as well as the preparation needed for part machining and programming. This includes enhanced CAD functionality and 3D model import support, improved part preparation and fixture setup tools, additional PowerSurface capabilities, and expanded support for Model-Based Definition (MBD).
Mastercam 2019’s expanded digital tool library capability delivers accurate 3D tool assembly models, with access to cutting tool data and updates for Sandvik Coromant CoroPlus and MachiningCloud platforms. This release also expands Accelerated Finishing with support for taper- and lens-style tools aimed at 75-percent cycle time improvement for finishing operations with superior surface finish quality.
With improvements to toolpath and machine simulation, toolpath graphics, and other verification and analysis tools, Mastercam 2019 provides greater programming assurance and allows for better, more informed decisions before a job is run, the company says. These improvements include support for block drilling multiple holes simultaneously and better axis control in simulation, enabling users to more easily check machine limits or collisions.
6 Tips for Training on a Swiss-Type Lathe
There are nuances to training a person to effectively operate a Swiss-type lathe. Derek Korn, Production Machining’s editor in chief, shares suggestions from a CNC machine shop.
A Career at the Top Helps Rebuild a Job Shop
A new approach to management propels expansion into Swiss-type and multitasking machining work.
Finally, A Comprehensive Software Solution Designed for Small Job Shops
