Updated CAM System Supports Tool, Fixture Libraries
Gibbs and Associates’ GibbsCAM 2015 includes enhancements for specific functions.
Gibbs and Associates’ GibbsCAM 2015 includes additions for tool definition and support for tool types including lathe and mill form tools created as 3D solids; 70-degree (ISO E-style) lathe tools; and straight, tapered and stepped mill tool shanks. The software also supports tool blocks and fixtures, and includes a fixture library. The 2015 release is integrated with Sandvik Coromant’s Adveon Tool Library, which enables importing cutting tools and intermediate tooling from Sandvik and other ISO-13399-compliant systems.
For users of complex machines, the Universal Kinematic Machine (UKM) architecture enables programming and simulating machines of any configuration, including multi-axis mills or multi-spindle, multi-turret, multitasking or Swiss-type machines. UKM is said to provide more accurate simulation and is backward compatible with postprocessors.
Improve Machining Efficiency Through Digital Twin Simulation
Full simulation of a machining cycle using digital twins can not only identify crashes before they happen, but provide insights that enable the user to reduce cycle times.
TTI Brings Specialty Gear Production In-House with Multiaxis Machining
By investing in a 3+2-axis machine and utilizing simulation software for diagnostic checks, Techtronic Industries turned a four- to ten-week lead time into a one- to two-week lead time.
Large-Format Machining With Small Cutting Tools and Dynamic Motion
Napoleon Machine, a defense contractor that provides parts for the M1 Abrams tank, recently took advantage of a CAM feature that allowed the company to streamline its cutting strategies and program offline. Here’s how the shop cut cycle times nearly in half with its large-format five-axis machining operations.
