Use Synchronous Technology for NC
(Sponsored Content) Explore the opportunities and see the video on how painless model editing can be in your NC environment.
Advertorial From: 8/2/2011 Modern Machine Shop
NC programmers are often stuck using the geometry they are given, even when changes would make the job go smoother. But take a look at the kinds of model manipulations you could take advantage of as part of your NC process. In a few short minutes we'll introduce several cases in which model edits can impact the effectiveness of NC programming.
Don't worry about who built the model, or what system was used.
Synchronous technology makes it easy to edit models no matter who built them, without getting bogged down in their construction process. Make the edits that help you develop NC programs, without affecting the model source.
See what you can do when you have the power to take your NC process beyond the part modeling source. CAM Express from Siemens PLM Software.
More at 800-807-2200
MMS Zones
Zones
Supplier Categories
SmartCAM features New Mill/Turn Sub-Spindle and B-axis Support, Morph Pattern Roughing.
HSMXpress is full
featured 2 1/2-axis
CAM for SolidWorks.
Best of all, HSMXpress
is absolutely FREE!
Increase your productivity and bottom line!
www.surfcam.com
iMachining - the
Revolution in
CAM. 70% Time
Savings or More.
Greatly Extended
Tool Life!
• 2-5 Axis Milling
