Vacuum Chuck for Workholding Flexibility
The VM100 is designed for grinding non-ferrous materials on a magnetic chuck.
New Product From: 6/15/2010 Modern Machine Shop
The VM100 is designed for grinding non-ferrous materials on a magnetic chuck. The system can be used as a pallet changer and is equipped a the standard 14" × 12" vacuum pallet. Keeping the system clamped in vise reduces setup time. The VM100 operates using shop air (70 to 100 psi), eliminating vacuum pumps and coolant traps. It is designed to enable users to create their own vacuum fixtures.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Mitee-Bite Products LLC
MMS Zones
Zones
Supplier Categories
Self centering vise is a cost effective and universal workholding method for five sided machining.
There's more on workpiece holding and positioning in the Techspex Resource Center.
