Missile Lube 5 EH is a hybrid water-soluble concentrate that combines vegetable oil, synthetic oil and mineral oil for lubricity. The coolant is designed to serve many applications and material types. The primary applications are boring, reaming and deep hole drilling of aluminum alloys. Because of the lubricity, the coolant can be used at lower concentrations than conventional oil-based coolants, according to the company. The coolant, says the company, has helped some companies switch from using straight cutting oils while still achieving the required surface finishes.
Unist's Electronic Control Regulates Lubricant Delivery
Unist’s Pulse R electronic control ties into the system control solenoid valve and takes the place of a pneumatic pulse generator timer or logic block.
Ultra-fine Filtration of Cooling Lubricants
Vomat filters act as an important, value-adding factor in metalworking.
Rego-Fix Toolholding System Reduces Coolant Consumption
