Vertical Knee Mill CNC Now Also Configurable for Bed Mills
Eastec 2019: At Heidenhain’s booth, the Acu-Rite Millpwr G2 control will be highlighted, marketed as an easy-to-operate CNC for vertical knee mills.
At Heidenhain’s booth, the Acu-Rite Millpwr G2 control will be highlighted, marketed as an easy-to-operate CNC for vertical knee mills. A configuration for bed mills with AC motors is now available. At the booth, this system will be digitally connected to a larger monitoring system via Heidenhain’s StateMonitor software.
The control is available with an optional AMI (auxiliary machine interface) offering users the ability to interface as well as control its host machine tool’s spindle. The Millpwr G2 is equipped with full 3D contouring capabilities and is available as a complete retrofit package for two- or three-axis knee or bed mills. It is said to provide straightforward 2½-axis conversational shopfloor programming as well as powerful calculators, eliminating the need for time-consuming manual calculations and learning complicated programs
Heidenhain will also display its TNC 640 mill-turn control.
Key CNC Concept No. 1—The Fundamentals Of Computer Numerical Control
Though the thrust of this presentation is to teach you CNC usage, it helps to understand why these sophisticated machines are so important. Here are but a few of the more important benefits offered by CNC equipment.
Swiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
