Vertical Pick-Up Machine Reduces Idle Time
Emag’s VL 2 P is a twin-spindle, vertical pick-up turning machine that uses pendulum technology.
New Product From: 7/4/2012 Modern Machine Shop
Emag’s VL 2 P is a twin-spindle, vertical pick-up turning machine that uses pendulum technology. Featuring integrated pick-up automation, a polymer concrete machine body and a vertical design that facilitates chip-flow, the machine is designed for accurate, low-cost machining of workpieces ranging to 100 mm in diameter.
While a workpiece is machined in one spindle, the other picks up another raw part for machining immediately after. Combined with the machine’s compact design, this configuration provides short chip-to-chip times, the company says.
The company will also display its VL 5i vertical turning machine and VSC 400 DDS turning and grinding center.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
EMAG L.L.C.
MMS Zones
EMAG L.L.C.
Zones
