Vertical Spindle Five-Axis Bridge Machining Center
The Flymill vertical spindle five-axis bridge machining center series is designed to offer users a wide working range within a limited factory space.
New Product From: 8/12/2010 Modern Machine Shop
The Flymill vertical spindle five-axis bridge machining center series is designed to offer users a wide working range within a limited factory space. The series consists of four models: Flymill 1000 (39.4"), 1300 (51.1"), 1600 (63") and 2000 (78.7"), named according to the working capacity of the Z-axis in mm.
The machines are available in three different X-axis capacities, measuring 98.4" (2,500 mm), 157.5" (4,000 mm) and 137.8" (3,500 mm), while standard Y-axis travels vary between 78.7" (2,000 mm) and 315" (8,000 mm). According to the company, the large-capacity work table, rigid structure and large working range make the series ideal for machining large, single workpieces as well as time-sensitive production machining operations.
The machining center is outfitted with a 40-kW power continuous C-axis direct-drive head with rotation speeds ranging to 100 rpm, and A-axis rotation of -105 degrees to + 120 degrees, enabling the machine to perform complex 3D and five-axis machining.
The flexible series is suited for aerospace, automotive, die and mold, precision machining and power-generation applications. It can be configured with dust extraction systems, tool magazines from 30 to 150 tools, complete machine enclosure, laser probing, laser tool presetting and complete turnkey solutions.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Breton S.p.A.
MMS Zones
KOMA Precision, the finest the world has to offer in machine tool Productivity Innovation.
