Vertical Thread Grinder Performs Multiple Grinding Operations
Mitsui Seiki will display its VGE60A high-precision universal vertical thread grinder, providing a variety of grinding options for the manufacture of precision lead screw-type parts.
New Product From: 7/17/2014 Modern Machine Shop, , from Modern Machine Shop
Mitsui Seiki will display its VGE60A high-precision universal vertical thread grinder, providing a variety of grinding options for the manufacture of precision lead screw-type parts. In addition to thread grinding the machine can perform spline, gear, OD, surface, and edge grinding operations in a single setup, saving production time and improving part accuracy. The machine accommodates a maximum grinding length of 600 mm and an overall shaft size of 80 mm in diameter (with the largest-diameter wheel) and 700 mm in length. An automatic grinding wheel changer, an automatic wheel guard and a CNC wheel dresser (to accommodate differently shaped wheels) further increase productivity. Programmable grinding wheel tilt angles ranging from +45 to -90 degrees also expand grinding application opportunities. The vertical orientation of the work improves overall precision by eliminating workpiece “sag” and requires less floor space than a similar capacity horizontal grinder. The machine is compatible with both oil- and water-based coolants.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Mitsui Seiki Inc.
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
