Vertical Turning Center Supports 2,000-kg Loads
Toshiba Machine Co. America offers the TUE-100 vertical turning center.
New Product From: 7/21/2014 Modern Machine Shop, ,
Toshiba Machine Co. America offers the TUE-100 vertical turning center. With a 1-m (40") table diameter, the turning center is designed for high-speed, heavy-duty cutting of loads ranging to 2,000 kg (4,400 lbs).
The machine uses a design based on that of the larger TUE series models, including an identical ram cross-section to support the railhead for increased precision.  Sitting within a more compact 5 × 3.5 × 4-m (200" × 138" × 174") footprint compared to larger models, the turning center features a cast iron bed designed for efficient chip removal. Two types of bearings support both the radial and axial loads of the table, improving cutting performance. A range of table speeds are offered in order to provide quality surface finishes on a variety of materials. The TUE-100 turning center offers feed rates ranging to approximately 2,000 mm/min., reducing cycle times and increasing productivity, the company says.
See what you missed at IMTS 2014!
Check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology, then watch Shop Talk to get the Modern Machine Shop editors’ take on IMTS, the trends they’re seeing, and what’s coming next in your industry.
Learn More about IMTS 2014
Toshiba Machine Co., America
Zones
  • Techspex
