Video: Basics of Thin Wall Machining
To mill thin walls in aluminum using fast light cuts, machine on alternating sides of the wall all the way down, jumping the wall with each new pass.
This video shows a basic example of thin wall machining. Note how cuts alternate from one side of the wall to the other. This leaves the wall supported from both sides throughout the cut. Machining conditions: 10,800 rpm, 236 ipm, 0.75 inch dia. tool, 0.2 inch depth of cut. Video courtesy Mazak.
To mill thin walls in aluminum using fast light cuts, machine on alternating sides of the wall all the way down, jumping the wall with each new pass. This leaves the wall supported on both sides by unremoved stock close to where the tool is cutting. The video illustrates this.
When a pattern of thin walls makes up a series of pockets, machine the pockets incrementally.
Increasing OEM Visibility to Shopfloor Operations for the Win
A former employee of General Motors and Tesla talks about the issues that led to shutdowns on factory lines, and what small- to medium-sized manufacturers can do today to win business from large OEMs.
Machine Monitoring Boosts Aerospace Manufacturer's Utilization
Toolpath-Level Machine Monitoring Improves Aerospace OEE
Machine monitoring software that records historical efficiency to the toolpath level helped aerospace manufacturer Leesta improve its OEE by ten points.
