Video: High Speed Milling—900 ipm
Demonstation illustrates the kind of metal removal rate that is possible in aluminum at dynamically stable speeds.
Loading the player ...
This video graphically illustrates the sort of metal removal rate that is possible in aluminum when a milling machine is run at its most dynamically stable spindle speed. Note the relatively quiet sound of the cut.
The cut actually is just a demonstration, because this feed rate would impair the machine’s ability to hold fine tolerances. The video was provided by Boeing’s Research and Technology group in St. Louis, Missouri. For more information on milling at dynamically stable speeds, see the article under “Editor Picks” at right.
Why Go Five-Axis: Machine Types and Benefits
How to Successfully Adopt Five-Axis Machining
