Video: Racing Engine Oil Pump Gear Produced through Additive Manufacturing
High complexity and low quantity made this critical part a candidate for 3D printing.
Gears are expensive parts to make in small quantities. This video from 3D Systems describes how just one gear—for an oil pump—was critical to overcoming a problem with excessive oil pressure in a Mitsubishi 4G63 race engine for a car run at over 185 mph.
English Racing of Camas, Washington, knew that a change in gear size might solve the problem, but the team didn’t know how to get this gear. The complex custom part would have been costly to machine as a one-off job, particularly since one-off prototypes would also be needed to test and refine the design.
Metal Technology of Albany, Oregon, proposed additive manufacturing instead, growing the part directly from the CAD model on its ProX 300 direct metal sintering machine. This video shows the part not only being additively manufactured in this way, but also functioning successfully at full speed within the engine.
SolidCAM Wants to Help Machine Shops Get into Additive Manufacturing
SolidCAM's partnership with Desktop Metal is aimed at making additive manufacturing more accessible to job shops and other manufacturers.
Ford Partners With Rockwell Automation to Advance EV Program
The companies will jointly collaborate on assembly tooling designs and architectures that will increase speed to market.
Siemens and Mahle Partner to Develop Wireless EV Charging
Mahle will contribute its experience as an automotive supplier and Siemens will use its expertise in the field of charging infrastructure to develop wireless charging stations for electric vehicles.
