VMC Accommodates Large, Heavy Workpieces
The base column of Okuma’s Millac 852V II vertical machining center features ribbing to counter chatter and twisting during heavy-duty cutting.
The base column of Okuma’s Millac 852V II vertical machining center features ribbing to counter chatter and twisting during heavy-duty cutting. With its variable-speed gearhead and large-diameter spindle bearings, the VMC is capable of heavy-duty cutting and high-speed machining with high torque from low to high speeds. The worktable accommodates large, heavy workpieces ranging to 3,800 kg (8,380 lbs). The X, Y and Z axes measure 3,050 × 850 × 750 mm (120.79" × 33.46" × 29.53"), and traditional box ways on all axes provide high accuracy and rigidity over the long term, the company says. Rapid traverse rates range to 12 m/min. (472 ipm) in the X and Y axes, and to 16 m/min. (630 ipm) in the Z axis. The Cat 50 Big Plus spindle offers speeds ranging to 6,000 rpm, and torque of 481/390 Nm (355/288 foot-pounds) 30 min./continuous.
Vertical Lathe Executes Heavy-Duty, Long and Continuous Cutting
New VT1000EX Vertical Lathe from Okuma America Corp. possesses the capability to cut and machine difficult materials through, according to Okuma, its highly rigid, mechanical configuration, extreme thrust and torque.
