Okuma
VMC Features Larger Work Envelope, Smaller Footprint
Okuma’s Genos M560-V vertical machining center combines a high-column design and CAT 40 Big Plus spindle to cut large, complex parts.
Okuma’s Genos M560-V vertical machining center combines a high-column design and CAT 40 Big Plus spindle to cut large, complex parts. The larger work envelope minimizes restrictions on workpieces, tool lengths and the rotary table. A highly rigid, thermally-stable, double-column construction gives this CNC machine the ability to withstand thermal deformation, resulting in improved machining performance, the company says.
A 30-hp spindle with 146 foot-pounds of torque enables the VMC to cut challenging metals such as titanium and Inconel as well as stainless steel and aluminum. A separate automatic toolchanger (ATC) door enables seamless tool changing without interrupting the machining process. The table moves only in the Y axis, while the spindle moves in the X and Z axes, enabling a smaller machine design and providing rapid feed rates, precise cutting and smooth surface finishes.
The machine includes Okuma’s Thermo-Friendly Concept thermal deformation compensation technology. Pretension ballscrews and bidirectional spindle cooling enable better control of the machining process. Optional Collision Avoidance and Machining Navi Intelligent Technologies are also available.
Okuma
MMS Top Shops
