VMC for Cutting Large, Complex Parts
Okuma’s Genos M560-VA-HC VMC combines a high column design and CAT 40 Big-Plus spindle to cut large, complex parts.
Okuma’s Genos M560-VA-HC VMC combines a high column design and CAT 40 Big-Plus spindle to cut large, complex parts. The larger work envelope minimizes restrictions on workpieces, tool lengths and the rotary table. A rigid, thermally-stable, double-column construction enables the CNC machine to withstand thermal deformation to promote improved machining performance.
The machine features a maximum machining volume of 1,050 × 560 × 460 mm (41.34" × 22.05" × 18.11") and a table size of 560 × 1300 mm (22.05" × 51.18"). The maximum load capacity is 900 kg (1,980 lbs). The X- and Y-axis rapid traverse speeds are 40 m/min. (1,575 ipm) while the Z-axis rapid traverse speed is 32 m/min. (1,262 ipm). The machine is equipped with an ATC magazine capacity of 32 tools and features a spindle speed of 15,000 rpm.
A 30/25 hp (22/18.5 kW) spindle with 146 foot-pounds of torque enables the machine to cut metals such as titanium, Inconel, stainless steel and aluminum. A separate ATC door enables tool changing without interrupting the machining process. The table moves in Y axis, while the spindle moves in X and Z axes, enabling a smaller machine footprint, rapid feed rates, precise cutting and smooth surface finishes, the company says.
The machine comes standard with the company’s thermal deformation compensation technology. Pretension ballscrews and bi-directional spindle cooling are designed to enable better control of the machining process. Optional Collision Avoidance and Machining Navi Intelligent technologies are available.
Best Practices: Machining Difficult Materials
Vertical Lathe Executes Heavy-Duty, Long and Continuous Cutting
New VT1000EX Vertical Lathe from Okuma America Corp. possesses the capability to cut and machine difficult materials through, according to Okuma, its highly rigid, mechanical configuration, extreme thrust and torque.
Additive/Subtractive Hybrid CNC Machine Tools Continue to Make Gains (Includes Video)
