VMC Offers Rigidity, Robot Compatibility
Republic Lagun's 4020 vertical machining center offers rigidity and stability, along with FANUC control and automated robot compatibilities.
New Product From: 8/28/2014 Modern Machine Shop, , from Modern Machine Shop
Republic Lagun's 4020 vertical machining center offers rigidity and stability, along with FANUC control and automated robot compatibilities. The modular VMC features Meehanite castings and a heavily ribbed construction for dimensional stability, wear resistance and vibration damping in order to more quickly perform heavy cutting of complex parts with three-, four- or five-axis interpolations. Rectangular boxways on all three axes include friction-free Turcite liners and are hardened and ground to provide a large contact surface area, damping and rigidity.
The VMC provides an 8,000-rpm, direct-drive, CT 40/BT 40 taper spindle with an air-purged spindle head. The 15-hp motor achieves 73 foot-pounds of torque at 1,500 rpm for rapid traverse rates of 1,000 ipm and cutting feed rates ranging to 400 ipmIn addition to automatic lubrication, the flood coolant system provides a 60-gallon capacity with flow rates of 21 gpm. Other features include a 24-tool automatic toolchanger, 2,200 lbs of tool clamping force and a table load capacity of 1,100 lbs. The automation-friendly FANUC 0i-Model D controller supports eight axes in total and as many as four axes in simultaneous interpolation. A high-speed Ethernet interface enables integration into a network for part program transfers and process-related data collection, as well as remote troubleshooting.
Options include 10,000- and 12,000-rpm spindles, fourth and fifth-axis capabilities, extended Z-axis travel, a 32-tool ATC, coolant-through spindle, and explosion-proof construction for machining hazardous materials.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Republic-Lagun CNC Corp.
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
