VMC's Dual Y-Axis Ballscrews Improve Surface Quality
IMTS 2018: Hardinge has added the Bridgeport V1320 vertical milling center to its Bridgeport V-series line.
Hardinge has added the Bridgeport V1320 vertical milling center to its Bridgeport V-series line. The machine is equipped with dual Y-axis ballscrews to improve surface quality, reduce vibration, increase acceleration, improve roundness accuracy and increase tool life.
It features a Mitsubishi M80 with a 15" screen. The control comes standard with two 32-GB SD card slots for memory expansion, USB running, a touch screen, high-accuracy modes and smooth surface software. The machine also features six linear guide trucks on the X and Z axes as well as rear chip evacuation. It is designed for machining both simple workpieces and complex parts for industries such as automotive, aerospace and medical.
Heavy Engineering: The Complex Logistics of Moving Large Machine Tools
One of our fascinations with large-format machine tools has little to do with their capabilities, but everything to do with the logistics involved with getting them up and running. Here’s how one of the world’s oldest builders of giant machine tools tackles the challenge.
