Sumitomo
Walter M5137 Xtra-tec XT Cutter Reduces Finishing Operations
Walter’s M5137 Xtra-tec XT shoulder milling cutter features 90-degree approach angles, which it says reduces the need for additional finishing operations.
A partial rendering of Walter's M5137 shoulder milling cutter
The M5137 Xtra-tec XT shoulder milling cutter from Walter has six indexes per insert, approach angles of exactly 90 degrees, positive geometry and two pitches for different applications. The company says this cutter’s exact 90-degree lead angle reduces the likelihood of needing additional finishing operations. ​Its fully sintered, triangular, double-sided indexable inserts improve process reliability and cost efficiency, while the insert design features easy cutting geometry.
A Tiger-tec coating and six cutting edges per indexable insert further reduce the Walter M5137 Xtra-tec XT’s process costs, while also simplifying tool selection and lowering cutting material and unit costs.
Walter says the milling cutter is universally compatible with steel, stainless steels, cast iron and other difficult-to-machine materials. The company recommends it for face, shoulder, ramping, pocket and circular interpolation milling operations in the energy and mold and die industries. The M5137 has a diameter of 2.0-4.0” (50-100 mm), a maximum depth of cut of 0.315” (8 mm) and a shell mill mount interface.
GWS Tool Group
Horn USA
Iscar
Sumitomo
SGS
IMCO
Ingersoll Cutting Tools
