The Mach 4 is said to improve part cycle time and accuracy. The waterjet combines the company’s HyperJet pump, rated at 94,000 psi, and Dynamic Waterjet XD, high-precision flat stock and 3D cutting technology.
The Mach 3 features Dynamic Waterjet cutting technology with a 60,000-psi pump. The Dynamic Waterjet is designed to eliminate stream lag and taper. The Mach 2 line is also available. It combines traditional waterjet capabilities, reliability and value, the company says. Also, it demonstrates the JetPlex 55,000-psi pump and FlowMaster software designed to optimize waterjet cutting.
