Without particular knowledge of G-code programming, it is possible to generate part programs with user-friendly software for shopfloor programming just by answering simple questions. FANUC’s Manual Guide i conversational programming is fast and efficient programming for milling, turning and mill-turn centers with FANUC CNCs. The innovative programming enables development from a drawing to a production part in a very short time, producing highly efficient results even for complex parts. A free webinar on Tuesday, January 22 at 2:00 pm EST will give an overview of the functionality of Manual Guide i. It will also highlight several steps to make setting up the software efficient and user friendly; setting up your tool library; and setting up both your turning and milling fixed forms. By the end of the webinar, you will know all the preliminary work you need to do prior to starting to create a new program.
Click here to register for the webinar.
