Weldless Molding Technologies: Conclusion Transcript
In molding, if you don't control the surface temperature, the resin
will not flow correctly, which will cause a weld or seam. There is a
new process that allows you to eliminate this problem and create
weldless or mold-free parts. In order to do this, you must have much
higher control of the mold and its temper
inMotion Transcript
8/27/2008
Modern Machine Shop
higher control of the mold and its temperature. We spoke about the
components of this new process and what it takes to create a 3D weldess
mold.
Editor's Picks
In this seminar, Makino will demonstrate weldless molding capabilities only possible with new, cutting edge technologies and techniques.
