Parts Cleaning Conference
Wet-Blasting Process for New Markets
The Sabre wet-blasting system from Vapormatt has been developed in response to customer demand to serve three new user groups: small- to medium-volume manufacturers, coating centers and R&D facilities.
The Sabre wet-blasting system from Vapormatt has been developed in response to customer demand to serve three new user groups: small- to medium-volume manufacturers, coating centers and R&D facilities. The company says it provides a cost-effective, high-performance wet blasting process to enhance output quality on a range of cutting tools.
The process uses a nozzle arrangement that focuses blast guns on critical tool faces and cutting edges, delivering consistent and controllable results. This ensures total coverage of tools, offering edge radii within ±5 micron tolerance of specification and a surface that will dramatically improve coating adhesion, the company says. The option to fit both X- and Y-axis nozzle arrangements facilitates user customization and makes it possible to process both round shank tools and cutting inserts in one system.
The wet-blasting system is suitable for round shank tools ranging from 3 to 30 mm in diameter and 46 to 307 mm in length and can accommodate as many as three Manz trays at one time. A compact footprint measuring 2.34 m² enables it to easily fit into existing production lines. The company says the control and monitoring systems offer consistent and reproducible processing.
Cleaning questions ask Kyzen
The view from my shop.
MMS Top Shops
