Wire EDMs Combine Speed, Precision
Available from Methods Machine Tools, the FANUC RoboCut α-CiB series of wire EDMs are designed for high precision, fast rapid traverse rates and expedited setups.
The series includes the C400iB, C600iB and C800iB machines, the latter of which accommodates parts as heavy as 5,000 lbs and as large as 49.2" × 38.4" × 11.8". All machines feature positioning accuracy of 0.0002" and repeatability of 0.0001". To maintain this precision, thermal displacement compensation technology accounts for temperature fluctuations that can distort the casting. The wire EDM column and lower arm are fixed so the table and workpiece move rather than the column.
The 3D Compensation Function reduces the need for indicating-in workpieces, enabling the operator to measure the flatness of the workpiece and automatically tilts the wire to make it perpendicular to the surface of the work, reducing setup time. Core Stitch slug retention prevents slugs from dropping and eliminates the need for clamps, further increasing efficiency.
All machines employ the FANUC series 31i-WB wire EDM CNC 15.1" LCD touchscreen, iHIMI (Intelligent Human Machine Interface), large program storage capacity, and remote PC access from handheld or desktop devices. Cut Linki remote machine monitoring software version 2.1 monitors as many as 32 FANUC wire EDMs, providing information on consumable life, machine efficiency, utilization time and maintenance.
5 Tips for Getting the Most From the Historic Return of North America’s Biggest Manufacturing Event
Plan. Explore. Think of the future. And oh yeah, the shoes. Here is how to get the most from the major manufacturing event that none of us have experienced in four years, and that many will be experiencing for the first time.
Combination Lathe Enables Both Manual, CNC Operations
IMTS22: Milltronics showcases its ML16II/40 combination lathe, as well as its VM3018IL performance vertical machining center.
