The Abrasive Diamond Surface Grippers, produced by Fairlane Products, have gripping surfaces comparable to 100-grit sandpaper. This surface is bonded to a stainless steel pad to grip smooth or slippery surfaces with minimal clamping force and surface marking. The wear resistant diamond particles transfer holding pressure to a small and well-distributed area. The grippers are available in various sizes and configurations.
Also available is a range of manual clamps produced by Imao. These include miniature, heavy duty, swing, pull, push, rocker and snap clamps with forces ranging from 150 to 2,250 lbs. These retractable clamps are made of alloy steel that has been heat treated and finished in black oxide. They are designed for repetitive or quick clamping operations.
Other offerings include the Fairlane Products line of grippers, rest pads, Swivots swivel/pivoting positioning components, Quick Release ball-lock pins, rollers and bumpers; Kipp spring plungers, rest and riser pads, levers, handles, knobs, and hand wheels; Imao supports and stops, risers, T-nuts, sliding mounts, springs, supports, grid plates and blocks; OK-Vise single- and double-wedge clamp designs; Mitee-Bite low-profile edge clamps; and the Modern Industries mPower product line, which includes quick change precision locating and mounting systems and modular tooling, plates and columns.
More technology – a lot more!
Learn More about IMTS 2012
