Workpiece Clamping System Features Quick-Change Capability
Röhm’s modular Captis workpiece clamping system provides a range of workholding options for turning, milling and drilling applications, featuring quick-change capability that is said to permit conversion from external to internal clamping in less than a minute.
Röhm’s modular Captis workpiece clamping system provides a range of workholding options for turning, milling and drilling applications, featuring quick-change capability that is said to permit conversion from external to internal clamping in less than a minute. The system is designed to produce strong clamping forces without deforming delicate workpieces while offering high repeatability and minimal runout. It is compatible with the BZI collet interface.
Emuge-Franken's New Drill Geometry Optimizes Chipbreaking
PunchDrill features patent-pending geometry with a chipbreaker that produces short chips to control machining forces.
Tungaloy Expands Drill System With Drill Sleeves
Adding drill sleeves to the standard lineup enhances drilling productivity of Swiss-type sliding-head automatic lathes.
Walter Offers New Solid-Carbide Taps for Blind-Hole Machining
Walter’s TC388 Supreme and TC389 Supreme feature patent-pending cutting geometries that fully shear off the root of the chip when reversing, thus minimizing torque peaks.
