Blog
Posted by: 22. August 2014
A Cleaner Audi TT
You may recall the contaminated water emergency that occurred earlier this month in and around Toledo, Ohio. The cause were toxins generated by algae, which bloomed in abundance due to the run off of things like fertilizer and other chemicals.
It’s called “eutrophication.”
Which I didn’t know until I started reading about the forthcoming Audi TT and the lifecycle assessment that Audi has conducted on the coupe.
Audi TT
Said Prof. Dr. Ulrich Hackenberg, board member for Technical Development at Audi, “Our goal is to reduce significantly the overall emissions of each model compared with its predecessor. However, it’s not just a matter of what comes out of the exhaust pipe. At Audi, we look at the entire product and process chain associated with mobility.”
Turns out that nitrogen oxides can contribute to the potential of eutrophication, as well as petrochemical ozone creation and acidification.
TT materials
Yes, this is in German, but you can probably figure out the steel and the aluminum.  Or you can just use Google Translate.
One of the ways that Audi addresses environmental impacts with the new TT is through lightweight construction. The new car weighs 2711.69 lb., which is 110.23 lb. lighter than the car it replaces.
To achieve a light structure, the company is using high-strength and ultra-high-strength steels for the front end and underbody and aluminum for structural and add-on parts.
They reckon that in the manufacturing process for the TT they’re reducing greenhouse gas emissions by approximately 9%, or 1,763.7 lb., and that overall, the third-gen TT has a lifecycle savings 6.05 tons of greenhouse gases.
Were there more companies like Audi, chances are concerns about drinking water would be less of a consideration.
Comments are reviewed by moderators before they appear to ensure they meet Modern Machine Shop’s submission guidelines.
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
Subscribe to these Related
RSS Blog Feeds
