A Fiber Laser Cutter for Job Shops
Trumpf says its BrightLine fiber laser-cutting technology enables its TruLaser Series 5000 fiber laser cutting machines to be just as effective processing thick materials as they are cutting thin sheet metal.
Trumpf’s BrightLine fiber technology delivers a quality cut edge with minimal burr
(shown on the bottom part).
Compared to solid-state laser cutters, CO2 lasers are generally faster for thick materials while offering better cut quality. On the other hand, solid-state lasers (fiber or disc) with greater beam power density and absorption characteristics are speedier and more energy-efficient when cutting thin sheet metal. However, at last year’s Fabtech show, I learned about new technology from Trumpf that enables fiber laser cutting machines to be just as effective processing thick materials as they are cutting thin sheet metal. Learn more.
Buying a Lathe: The Basics
