Aligned for Precision
To precisely condition the form, shape and finish of an inside diameter of a workpiece, no machine tool outperforms an ID grinder if (and only if) key components of this grinder are properly aligned. This article outlines the importance of this alignment, explains how to recognize the symptoms of misalignment and describes what corrective steps to take.
To precisely condition the form, shape and finish of an inside diameter of a workpiece, no machine tool outperforms an ID grinder if (and only if) key components of this grinder are properly aligned. This article outlines the importance of this alignment, explains how to recognize the symptoms of misalignment and describes what corrective steps to take. The author, Bill Bednarski, is an applications engineer at Saint-Gobain Abrasives in Worcester, Massachusetts.
The components on a basic ID grinding machine that must always be in alignment are the X- and Z-axis slides, the grinding wheel spindle, the grinding wheel truing dressing device and the workhead spindle. As the linked article above shows, a properly aligned ID grinding machine, along with the right wheel specification and optimized grinding cycle parameters, will be a very cost-effective method to produce precision workpieces.
How To Passivate Stainless Steel Parts
You've made sure the parts were machined to spec. Now, make sure you've taken steps to protect those parts in the condition your customer expects them.
Key CNC Concept No. 1—The Fundamentals Of Computer Numerical Control
Though the thrust of this presentation is to teach you CNC usage, it helps to understand why these sophisticated machines are so important. Here are but a few of the more important benefits offered by CNC equipment.
